breech lock heat exchangers
WHAT ARE THE MAIN FAILURES THAT HIGH PRESSURE BREECH LOCK TYPE HEAT EXCHANGERS MAY EXPERIENCE DURING MAINTENANCE AND HYDROTESTING?
TANNKS IN ADVANCE
LUIS MARQUES
RE: breech lock heat exchangers
Just some friendly forum etiquette, large caps means your YELLING.
Tobalcane
"If you avoid failure, you also avoid success."
"Luck is where preparation meets opportunity"
What is the closure method for your breech lock type Hx?  (And I concur about the all CAPS).
rmw.
