NACE MR 0175 and EN 10204 3.1
Dear Friends,
For long time I've been a reader of this forum and at last joined myself. I'd like to appreciate all who are taking time to share their knowledge with people.
My question is about NACE MR 0175 certification requirement for materials. I know that this report/standard covers mainly hardness requirements, so would be appropriate to specify EN 10204 3.1 along with it? Basically the material certificates line would read as this: "- all pressure retaining and/or wetted parts according EN 10204 3.1 and NACE MR 0175".
Your opinion is highly appreciated.
RE: NACE MR 0175 and EN 10204 3.1
thread338-264003: valves who meet NACE MR 0175
The proposal is not strictly correct.  ISO 15156 is not a certification document; it is a document of materials requirements and environmental limitations.  Since it is the end user's responsibility to have selected the correct materials based on their knowledge of the service environment, it is extremely difficult for a supplier to certify compliance when they do not know the service environment.  You, as a specifier, must indicate which tests and inspections are required and then define that the results of such tests and inspections be incorporated into the inspection documents.  Gone are the days of simply asking for 'NACE'.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
SJones,
Thanks for your comment. This NACE certification requirement is introduced due to possible H2S presence in the flare and fuel gas system of the burners in a hydrogen plant. Our engineering are specifying NACE compliance in equipment data sheets and the detailed specifications are indicating where necessary "execution according to NACE MR 0175" and that "NDT records shall be provided". The line which I was asking is only for the Quality Control Plan. Don't you think this is sufficient for the vendor to understand what we want?
Rgrds,
JT
The vendor probably understands what you want, but can they give it to you within the letter of ISO 15156?  Your engineers appear to have done the usual: simply asked for 'NACE compliance' without reading the details of the standard.  In summary, if the end user wants 'NACE compliance', the end user must clearly state what constitutes compliance.
Steve Jones
NACE MR 01-75 does not address QA/ QC. So you should have QA /QC proceedures that demonstrate "NACE" compliance ( eg. frequency, method, location ,etc of hardness tests).
