AVO megger b131
AVO megger b131
AVO megger b131
Hi i find on my office a avo megger b131 and i wonder exactly what it does and how it works, so i surf on google, but i just find a data sheet and i´ll like to get something like a manual....
could somebody help me...as always thanks for your attention
RE: AVO megger b131
Google tells me that an AVO b131 is not a megger, it is an LCR meter.
Bill
"Why not the best?"
Jimmy Carter
RE: AVO megger b131
yes, but the package says dual display lcr meter from AVO Megger B131, i really don´t know exactly what could i do with it,
thaks...
RE: AVO megger b131
If you do not know what to do with an LCR meter - why do you feel like doing anything at all with it?
Gunnar Englund
www.gke.org
RE: AVO megger b131
AVO Megger is the company name. Actually, they just go by "Megger" now in the US, IIRC.  The marketing geniuses at AVO finally figured out that the tradename "Megger" has much greater value than AVO.
If it is functional, you could send it to me.  looking around
David Castor
www.cvoes.com
RE: AVO megger b131
" The marketing geniuses at AVO finally figured out that the tradename "Megger" has much greater value than AVO."
And to this day, when a guy on the job calls for a "megger" he wants an instrument for testing insulation.
Despite the marketing "genius".
old field guy
RE: AVO megger b131
They have TDRs also. Needed one when a guy went after a device with 'Megger' on it. 'No, not insulation - distance to fault' I told him. Age shows...
Gunnar Englund
www.gke.org
RE: AVO megger b131
Thanks, i know maybe i must know more about the use of LCR meter, but cause i need more info is why i ask you if somebody got a manual or some idea of all the features of this device.... more or less is clear that i could measure resistance above 10 ohms, and capacitances and inductances.... but i would like to read the manual that is missing on the box, cause some asshole lost it... and i try to write company and no reply.. so... in any way, thanks for your time.
RE: AVO megger b131
I must admit if someone offered me an AVO I'd expect a top quality analogue multimeter.
RE: AVO megger b131
sibeen,
That's because you're old. tongue
RE: AVO megger b131
Objection, your Honour!
It is because an AVO IS an AVO.
Gunnar Englund
www.gke.org
RE: AVO megger b131
so no way to find manual for this instrument, thanks for your time
RE: AVO megger b131
What!? I found a very good specification here: http://www.sjelectronics.co.uk/pdf/megger/B131.pdf
That is the first hit when you google "avo megger b131". What else do you need? Everything is in there.
Or do you need to know what resistance, capacitance or inductivity is? In that case you hardly need an LCR meter first hand but a text-book on basic electricity. They can also be easily found.
Gunnar Englund
www.gke.org
