Scrambled high quality image
Has anyone any idea what causes these scrambled renderings and how to solve/prevent it? See the attached example.
It happens in different versions of NX and in all rendering qualities. And if you got this error in a part file it stays there.
RE: Scrambled high quality image
I have seen a few cases when the perspective distance was "many kilometers" and the display got "splintered".
Try set the camera to "parallel" and render to see if this is the problem. Then set the perspective distance to some reasonable value.
Try going to...
View -> Camera -> Capture and Edit...
...and going to the section of the dialog labeled 'Clipping' and selecting the button labeled 'Fit Planes to Extents' and then hitting OK. See if that solves the problem.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Can render good pictures again.
Thanks..
