ASME VIII Div 1
ASME VIII Div 1
In pressure vessel calculations according to ASME VIII, Div 1, is the inside projection used in the area replacement calculations for hillside nozzles taken from the centerline of the nozzle? Or is it the shortest projection inside the vessel?
Thanks in advance.
Thanks in advance.
