EDM prototypes from 410 stainless. Harden the stacks or the parts.
This is my first post on this forum. Thanks for reading. Any advice is appreciated.
I have to make a snap ring from type 410 stainless steel. My question is this... Should I build the stacks and have them hardened first and then wire them out or should I just have the parts hardened after. The OD of the rings is 1.004" +/-.002". My concern is that they will move during the heat treating process and possibly warp. My associates say the parts may move regardless of which way we proceed. For reference I've uploaded a print.
Thank you.
Jim
Thank you.
Jim
RE: EDM prototypes from 410 stainless. Harden the stacks or the parts.
There is risk with either method. If you use wire EDM on a pre-hardened material, you can get a re-cast layer that is not hard, is cracked, or will initiate cracks upon loading. If you harden after machining, you may get distortion during quenching.
Are you familiar with how millions of these parts are made? It is by hardening after forming. However, a common process used is isothermal quenching in molten salt, which has much less distortion than traditional oil quenching.
Jim
We had case where the thickness didn't meet the design requirements which was resolved by taking a thicker shaft ring and using diamond lapping to get the required thickness. If my recall is working I believe the thickness was taken down 0,010"
