NASTRAN Composite Modeling with 2D contact
Hi everbody,
I try to simulate 2 body contact in 2D problem by Nastran (SOL 400). One of the 2 body is composite material, but i don´t know why Nastran no consider the contact between them.
Is it posible to do it? or i have to change it to 3D problem?
Please help.
Thank you
Please help.
Thank you
RE: NASTRAN Composite Modeling with 2D contact
If you set right them, you should not have problem.
If you want an example of contact using SOL700 contact me, I'm just study this argument.
Thank you, really I read all the commands, but maybe i didn´t see the solution.
Can you send me your example?
I´m grateful to you.
http://
this is a problemi with sol 400!
htt
htt
htt
htt
Thank you for your help, but when i was reading the *.dat, there is no MAT8. The problem is that when i want to simulate 2 plate (composite material) in 2D problem (X-Y plane) with a contact there are problems:
1- If I use MAT8 with 3D contact, the solution not converge.
2- If I use MAT8 with 2D contact (the real case) the program can not recognize the material.
So, I don´t know why I have this problem.
Can you help me?
Thank you again.
