Oversized holes
Oversized holes
I have two instances where I have an oversized hole with a bolt that is 1/4" to 3/8" oversized. The first is an anchor hole, there is a 3/4" bolt in a 1 1/8" hole. If I have checked the bolt and base plate to resist the shear, fatigue is not an issue due to the low frequency of the building and there is a washer that covers the hole for uplift resistance, have I performed an analysis that will cover all aspects of an oversized hole concerns?
The second location is a purlin connection. The purlin is an axial member, so again a check for shear on the bolt and shear block on the member, as opposed to a bearing situation and fatigue analysis( once again not a concern due to the low frequency of the structure). There is no tension force on the bolt so the washer pullout is not a concern. All these parameters are meet are there any other areas of concern if the washer is not welded to the member?
RE: Oversized holes
RE: Oversized holes
I don't like using purlins to resist axial loading, although I know some people do it.
RE: Oversized holes
I also agree with hokie that the you need to provide a plate washer (with a standard hole) that gets field welded to the baseplate to take out the shear (if that is the load path you choose to use).
RE: Oversized holes
