Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This forum is the most helpful site I've ever used. I used to use Deja.com; but, this site is better - hands down!..."
Geography
rgrayclamps (Mechanical)
21 Feb 11 11:49
Something happened to my Solidworks recently.  Now, I can not use any Macro.  Whenever I try to run a macro, the following message appears:
"swVBAServer has stopped working."
I talked to my VAR, and did not get a solution. Do you folks know what may cause this problem?
Best regards,
Alex
Windows 7 Pro, SW2010 x64 sp5.0
fcsuper (Mechanical)
21 Feb 11 11:53
I've not heard of this issue before.  Have you cleared out your registry to allow SW to reset file location settings?
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
21 Feb 11 11:57
Hi, Matt:
I did clear out the registry, but it did not help.
Best regards,
Alex
CorBlimeyLimey (Mechanical)
21 Feb 11 12:55
Try running a repair.
21 Feb 11 14:27
I tried a repair.  It still has the same problem.  I googled swVBAServer and found some discussion on it related to virus.  Not sure if it is a virus.
Best regards,
Alex
macduff (Mechanical)
25 Feb 11 9:26
Things seem to be working fine on my end. FYI, I ran an update from SP3.1 to SP5.0. I did not do a clean install.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 5.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
28 Feb 11 13:39
My instinct is that this is a corrupt install and may require a new install.
Matt Lorono, CSWP
robbol (Computer)
26 Apr 11 13:23
I had similar issue.
In my environment, if I logged in as a different user the VBA editor worked within Solidworks.
The way I resolved it was to copy the registry settings for
HKEY_CURRENT_USER\Software\Microsoft\VBA from the working user.
Then logging into the user that didn't work. I did the following:
1. Backed up HKEY_CURRENT_USER\Software\Microsoft\VBA registry
2. Deleted registry settings that I backed up above
3. imported registry settings from working user
Close Box
Join Eng-Tips® Today!
Join Us             Close
