Section Letter
Section Letter
Section Letter
Were do you edit or asign the hight of the letter at the side of the section arrows.
Thank you
RE: Section Letter
Just double click the letter, it will open the annotation style window. Goto Lettering>General and change the charector size
AK
NX 3.0.5.3
RE: Section Letter
It's under File- Utilities - Customer Defaults- Drafting- General - Standard - customize standard - View Label - Section - Letter size Factor. ( where the default 1.4 means 1.4x the default General text height., if General text height is 3.5mm, 1.4x3.5=4.9mm)
 Tomas
RE: Section Letter
Hi Toost,
Thank you for your reply.
I have changed the setting you said about & all is good now.
NX 7.5
HP Mobile Workstation XP Pro
