Welded T-Joint Tests
We're looking into doing T-joint tensile tests on welded steel specimens (A992 and A 36) but are having a difficult time find testing information?  Is there an AWI or ASTM test protocol for such a test?  If so what is it?
Thanks in advance,
RE: Welded T-Joint Tests
Not that I am aware of.  Tensile testing is performed on a flat welded plate.
Tell us more about your T-joint.  Is it a complete joint penetration weld (full-pen)?  Or is it a simple fillet weld joining the two base metals?
Hoseman100, can you introduce detail more, so i think which is not enough information for looking for.
What welding code are you working to (if any)?
What is forcing you to perform a tension test on a T-joint?
A question properly stated is a problem half solved.
Always remember, free advice is worth exactly what you pay for it!
http://www.ap-dynamics.ab.ca/
