Calculating water level
Hi guys:
I am working on job in which require me to calculate the water level. I was thinking HEC-22 for water level calculation. I was wondering is there any spread sheet out there that I can do some study so I can modify my spread sheet?
tsli
tsli
RE: Calculating water level
(https
I have also used the Florida DOT version of this software. These are usually free!!! Regardless, I would start with your local DOT they will have a design procedure that will most likely be acceptable in your area.
Curt
