Is Brass FCC or BCC at room temp?
Experts:
Is brass FCC or BCC at room temperature?  Also,  I was wondering if it was Austenite or Martensite?  Specifically, the brass used in brass bearing races.  Thank you.
RE: Is Brass FCC or BCC at room temp?
Ha, like it's that simple!  Which brass alloy?  Below 35% Zn it's FCC, above it's BCC.  Neither is austenite or martensite.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Please read basic text book  on metallurgy by E.C Rollason,it will help .
_____________________________________
"The richer we have become materially, the poorer we have become morally and spiritually." Martin Luther King Jr
