Repair errors
Repair errors
Actually, posted this same question on the wrong forum at first....
A friend is working on an assembly drawing at work (she got that assembly drawing from someone else) during which solid works tells her the design needs to be REBUILT (I guess this is because of conflicts in references or mates). She does her best addressing the issue and has used the REBUILD command repeatedly but the software keeps asking her to rebuild. It's like a never ending loop. She'd redone the design several times but runs into this brick wall all the time.
Would appreciate some advice very much!
JJ
JJ
RE: Repair errors
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
RE: Repair errors
thread559-211837: top-down design in SW2008
thread559-258968: assembly rebuild icon wont go away even after hard requild!
-Dustin
Professional Engineer
Pretty good with SolidWorks
RE: Repair errors
Appreciate your valuable advice very much.
JJ
RE: Repair errors
Expand out the parts and their features. You will see which specific features are incontext ( > icon). Right click on those features and select "list external reference" (or similar wording). This will tell you an assembly that your parts were created in context of... my guess is it won't be your current assembly. You can edit the sketches to delete any incontext relations... don't actually delete sketch lines, delete sketch relations. You can recreate these relations in the context of your new assembly.
If the naming was the issue, I would recommend renaming the files the same way it was done before. Rename them back to original. Then rename them to your desired name using SolidWorks Explorer with the "where used" check box selected.
-Dustin
RE: Repair errors
RE: Repair errors
List External References\Select Break reference... if you want the part to update, then you need to learn more about in-contexting, because you seem to be in the situation most people get into when they are not sure about these commands. They can be very benefical if done properly, but can cause tremendous amount of grief if not done properly.
Please review this process I came up with years ago when I was doing SW automation with In-contexted parts - http:/
The bad thing is there are no step-by-step process to fix this, its going to require some understanding from you and your coworker to work out this problem. Read the help and some online tutorials and that will help you understand the process and how SW thinks when In-contexting.
www.scottjbaugh.com
RE: Repair errors
Another silly question on my part; as a larger gap is opened up between the two web members, the dimensions of the members change commensurately but nothing else does. I would imagine that disregarding the rebuild errors won't work as one needs to drill down into this more.
