MDMT when Blowing With N2
My Friends,
In several previous posts (example: thread124-181137: Safe operating conditions for Autorefrigeration potential) there is a question about how cold you can get blowing a hydrocabon system dry with N2. I haven't always felt we were that useful, but now that I was asked to specify some rail car MDMT for pentene service, the question was asked of me to calculate exactly that question: How cold can it get when purging with N2. Using Aspen plus I could get an answer by sensitivity analysis on N2 and Pentene, finding the minimum point (when the last liquid disappears). The temperatures were much colder than my peers realized, reaching (theoretically) below -30C. I knew the temperatures would be well below the boiling point, but didn't have reasoning that could be well communicated. Now I do.
Before I submit my conclusions I would like you to check my reasoning: The N2 and liquid hydrocarbon mix, some hydrocarbon evaporates and carries away heat from the remaining liquid. The minimum temperature can be calculated by energy balance. We could even calculate dT/dt, but we only care about the final temperature (dT/dt=0).
The enthalpy of incoming N2 is balanced by the heat being removed by evaporation:
Equation #1: N2flow*Cp*(Tsupply-T)=HCflow*HVap, where
T is the mixture temperature
N2flow is the nitrogen flow
Tsupply is the N2 supply temperature
HCflow is the hydrocabon flow leaving (evaporated)
HVap is the molar heat of vaporization
Cp is the molar N2 heat capacity
The HCflow depends on the vapor pressure, system pressure, and flow of N2
Equation #2: HCflow=N2flow * PL /(P-PL), where
PL is the vapor pressure which is a function of T from Antoine's equation
By reducing this down, the N2 flow drops out:
Cp*(Tsupply-T)=PL*HVap/(P-PL)
Since PL=f(T), this is most easily solved using the solver function in Excel.
The parameters that make the difference for a particular system are the N2 supply temperature, and the total system pressure (typically atmospheric worst case).
Does this seem right to you guys? Any comment is appreciated.
best wishes always,
sshep
best wishes always,
sshep
RE: MDMT when Blowing With N2
http:/
why not pump in hot N2 and that will vaporize the pentanes quicker.
Hey DCasto, If the reference mimics the BPVC, ambient temperature does not count the same as process temperature. I am not sure why. In any event -29C (-20F) is allowed for SA516 Gr7 material up to 1" thick without any impact testing. Impact tested carbon steel can go lower. It would seem that since -29C is a freebee, that would be the typical specification, but I bet alot of guys blow it in estimating the temperature. As far as using hot N2 goes, you can't control the who, when, and where of purging, so that kind of admistrative control for a railcars doesn't seem practical.
I have seen ice on our flare lines when we make pentene runs (probably puking liquid into the flare from somewhere), so I really believe it can get pretty cold with N2 blowing past liquid.
best wishes to you both,
Sean Shepherd
This is a good story you have. My decision is basically to chose a temperature requiring charpy tested or not- I am within about 2degC such that assumptions on the N2 temperature used for purging will make the difference. Probably I just stay with a temperature that will ultimately end up with a charpy tested requirement, and be good to probably -50degF (my memory also) as you remember.
Your advice has always been excellent. If either of us finds a reference in those rail regulations, I will be more than glad to give you a star!
best wishes always,
sshep
I've blown down carbon steel lines with ethane and ethylene in them, that is -120F and then purged them with N2 before repressuring them. and the lines are still in service at 2200 psig. look up cryogenic working of carbon steel.
Unless you use 304 SS, you won't be in compliance with your own rules that "you can't control the who, when, and where of purging, so that kind of admistrative control for a railcars doesn't seem practical."
I'd make it practcal or hire someone else that will.
your OP concerning CVN testing. Trying to read into the papers there is continual mention of ASTM A515-70 Normalized, A516-70
Normalized, A212, along with some older steels.. New steels
being considered are TC128 B and HPS 70. It kinda hacks me
off when they state that CVN values were acceptable or better,
better than what.
The information is pretty convoluted as it uses cross references
to AAR, FRA, and DOT. You might contact AAR to get the
specification for rail car steel. I will keep looking as I recall seeing a graphic that covers some of the physical properties of steels.
Discusses the various steels but I see no definitive specification.
http://w
b%201%20Background.ashx
Concerns Weld and inspection. There may be lead to material
specifications
http://
ber%20Sub%202%20Background.ashx
See page 85 by Adobe
http://w
Here is an AAR search page.
http://
3Ke39K9UrX4HShCIBgEyTYkEAQ7MGIzeaS7B1pRyMpqyqBymVWZ
V1mFkDM7Z28995777333nvvvfe6O51OJ%2fff%2fz9cZmQBbPbOSt
rJniGAqsgfP358Hz8ifvzHd3%2fXp%2fl5ti7b3%2fXHf%2fze7%2fu74
r%2b93%2fd33fl9f9fte5%2fSv7v4gFr9vr%2fv7%2fu7%2fqL6Gj9%2b
%2fMf3fl95qJn%2b0rR5XqbNKp8W58U0a4tq2Zjv7P8NHPcBdfC7rq
flt%2fNslte%2fG%2f32Os%2fq6fx3m7blzj3%2bd8f%2flwHgpf7%2fC
NDv%2bv8A
I have as well worked in an ethylene plant some years back. Surely you have procedures to pressurize with ethylene vapor before introducing liquid, and also to drain and vaporize this liquid before depressuring to atmospheric or blowing with N2. Deliberately exposing carbon steel pipe and vessels to -120F does not seem right as the written procedure. It sounds like it would be like documenting a criminal act (but I'm an engineer not a lawyer). The chance of a crack from brittle fracture seems too high. I know the high quality of your posts and I think it would be out of character for you to do something like that deliberately, although we know it happens sometimes by accident.
My service is pentene. My calculated temperature is -30C and easily within the limit of impact tested steel. In fact, I'm only 1C away from no impact testing. I am looking for a purging N2 temperature standard (if there is one), I used 20C, but if it were 25C I would have a temperature above the threshold. In the end I will specify a MDMT that will result in impacted tested requirements.
best wishes always,
sshep
But what happens when a line is cut and the whole 20 mile section of line is blown down to atmosphere? How do you perform maintenance in the middle of nowhere? What happens when a interconnection has a relief valve failure?
NO, brittle fracture doesn't happen, because the stress on the line is low at the same time the temp is low.
what penetene has a -30F boiling point, all the ones I'm familiar with are closer to +30F and have mole wts closer to 68.
Finally, why do you use liquid N2, why not gaseous N2 for purging? Use gaseous and all your issues disappear.
