Transverse Post-Tension Anchorage of Box Beams
A while back somebody asked this question and the thread has been closed.  I was curious if anyone knew the answer to this question?  It is shown below:
"We are performing construction services for a project on which we also performed the design.  The superstructure is comprised of prestressed concrete, adjacent BI-48 box beams.  Based on NJDOT specifications, the fabricator is to design and detail the transverse post tensioning rods/strands and all anchorage details.  The typical detail has a 3" diameter sleeve in the beam to accommodate the transverse ties with a steel washer plate over the opening (typically 6"x6"x3/4").  We have received the calculations and for the steel washer plate the contractor calculated the required thickness to satisfy shear requirements based on the following calculation:  Shear area =Pi*3"(diameter of sleeve)^2/4  * plate thickness * sqrt(2)My question is if bending of the plate should also be considered.  Anyone have experience designing the steel washer plate for this type of bridge?"
-Thank you
