Scale Projection View
  I created a projection view, showing the bottom of the part. I will display this view on another sheet & want to enlarge it.  I do not see an option to scale the projection view larger.
  How can I do this or I can I demonstrate a projection view & scale it?
RE: Scale Projection View
I believe if it is a direct projection from another view you won't be able to scale it.  However, you can change it to a general view and then scale it.
Hope this helps,
gil
  Yes, the view was originated from a direct projection, which is what I  want.  However, I wish to put the view a little bit larger & either place it into a different zone area or onto another sheet.
  I have a directional section view that demonstrates where the view comes from.
  If I convert the projection view to a general view, then I lose my directional section arrows.
  Any other work arouds?
You can create another parent view to use for the projection which is created at the desired scale. Then create a projected view from the scaled parent to get the larger scale.
Another method would be to create a detailed View of the projection which will allow a custom scale to be applied. You can move or hide the Detail View name if you don't want it shown on the drawing.
The detail view can be a full view if you sketch the boundary for it large enough. You can also choose to hide the boundary in the detail view.
Michael
