Dog leg in a dimension line.
Is it possible to put a dog leg in a dimension line, similar to an ordinate dimension in NX4? I have never seen it, but one of your users is convinced it it used to be available in the utility library of the user defined symbols?
Thanks guys.
Thanks guys.
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX7.5 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
RE: Dog leg in a dimension line.
To create a User Defined Symbol you can do-
File->Utilities->Symbol Fonts... and select a .sbf file (You can create an empty .sbf file using notepad and save it to UGII directory (preferred), before selecting that file.)
Then create a New Symbol, give some name and select the dogleg lines and anchor point/s (You can create a dogleg by basic curves & select these lines for symbol creation)
I did tell the guy that this would be more than likely be the outcome, however he was convinced that there was NX functionality that would do the same.
Best regards
www.jcb.com
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
NO he was convinced it was like a dog leg on an ordinate dimension, however I think he must be confusing it with something else. thanks for all the input though.
Best regards
www.jcb.com
A question ...
If I explore the 'User Defined Symbol' method, is this going to be associative to the feature being dimensioned?
John R. Baker, P.E.
Industry Sector
Cypress, CA
