Hole callout interpretation
I cannot find ansi instructions on how to interpret depth callouts for holes on an angle. Typically I understand that the diameter has to meet the depth callout.
(.095 dia x .125 deep)
On an angle this means that there would have to be .125 of full .095 diameter correct?
Where can I find this in a manual or standard?
RE: Hole callout interpretation
"Where the depth dimension is not clear, as from a curved surface, the depth should be dimensioned."
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
