Clicking before eracing..
hey ,
hope someone can help me.
im using Autocad LT at work and 2000 at home.
It seems that the two versions are configured differently.
At home I can select the items first and then when i use a command eg. erace, the ithem selcted earlier are automatically eraced or selected to erace.
How ever at work, even though i have sellected the items earlier, and then chose to erace them ,the items earlier selcted will be clared and i will be promted to reselect the items again.
how do i customize it to select before eracing and vice versa?
Hope you can help
Daniel Luke
daniel@akiworld.com
RE: Clicking before eracing..
from tools menu >>> options>>> go to selection tab>>>make sure that the option Noun/verb seclection is checked, click ok , now u can select before the command.
Pea$e
