ASME Section VIII Div 1 UG-37 area replacement
Hello everyone,
I am trying to design the reinforcement for a new nozzle and found that the current layout I have is not support by the program Codecalc. I have resorted to doing the area replacement calculation by hand, but was wondering if the methods described in ASME VIII Div 1 UG-37 are not valid for a certain large theta or x values as shown in my diagram. Any advice on the matter would be greatly appreciated. Thank you in advance!
RE: ASME Section VIII Div 1 UG-37 area replacement
Are your dimension such that the nozzle is tangent? Is the nozzle OD outside the shell OD maybe?
Mike
www.pdhonline.org/courses/m205/m205content.pdf
Codecalc's marketing material says it can do it, although I haven't used it myself.
One last question. Is there some way to combine a hillside nozzle and an angled lateral nozzle? In my scenario I have a hillside nozzle as described above that is angled upwards from the horizontal a couple degrees. This will obviously increase the cutout from the vessel which needs to be accounted for.
Again, any help would be much appreciated.
Use vector addition to get the combined angle from the repad area, then use that derived [larger] angle to compute the minimum size for the repad. In other words, 'trick' CODECALC into thinking that this is a simple angle [which it can calc] versus a compound angle [that it can't].
But for a couple of degrees of inclination, I would just process the diameter twice. Figure out d' due to 2 deg inclination, then use that enlarged d as input for the hillside calculation. It's bound to be over-conservative, but for 2 degrees it shouldn't matter.
