using letters for cutting in sheet metal
Is it possible to use words and then change them for off setting so there is a gap between the letters so they can be cut out in sheet metal im using 2005 would be very helpful if this is possible.
RE: using letters for cutting in sheet metal
Look at sketch text. You'll have access to tons of fonts/sizes that you can emboss, deboss or simply use to create a boss.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
You can create a feature with text as the sketch and then cut, emboss, or raise that into the part.
It is usually a PITA since you are restricted on available fonts.
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
