H- Series Steel Joist
I am working on a retrofit/ remodel of an existing structure.  I have the original shop drawings for the steel framing.  I need the properties for a 10H3 and a 12H3.  The load tables will work as well.  The 10H3 has a span of 15' and the 12H3 has a span of 19'.
RE: H- Series Steel Joist
SJI just responded.  It took them about 5 min. after my inquiry to get an answer.  That is the best service I have ever had!!  Hats off SJI!!
