Looking for old B16.5 version
Does anyone out there have a copy of ANSI B16.5-1981? I need to know if there was a differentiation in the pressure/temperature ratings between SA182 F304H and SA182 F304L.
Any help would be appreciated.
Thanks.
Thanks.
RE: Looking for old B16.5 version
This is the first step I use for any research regarding the ASME Code. I have access to the full version, however, you are able to download the free trial program which is pretty extensive. see attachment for link...
RA-search (Rapid Access Search) allows rapid access to information that usually takes hours when searching manually. RA-search currently includes the following information bases:
• Code Interpretations allows you to quickly find any Interpretation published by ASME for all ASME Codes and Standards as well as all published interpretations of the National Board Inspection Code.
• Code Revisions gives you quick access to descriptions of all ASME Boiler and Pressure Vessel Code revisions since 1977, including Sections I, II, and VIII to 1952, and Section III to 1963 as well as descriptions of all revisions to B31.1 from 1955, B31.3 from 1959, B31.7 Draft through 1969, B16.5 from 1968 and B16.34 from 1973
_________________
A question properly stated is a question half solved.
FAQ731-376: Eng-Tips.com Forum Policies A question properly stated is a question half solved.
