Pressure vessel for hire/lease as fixed-bed reactor
Hi, We're working on a project for mercury/arsenic removal from the condensate rundown line and we've identified and sourced a proprietary metal sulphide absorbent material to do the job.However the client wants the system on a temporary basis (approx 6 months) as it is inconclusive whether there will actually be any mercury/arsenic present. The approach is to lease/hire a pressure vessel for 6 months, which can be packed with the adsorbent material and used as a temporary fixed-bed reactor. Op pressure and temp is 10barg & 50 degC. They do not want to fabricate a vessel from scratch. Does anyone know of any vendors (preferably located in Asia-Pac region)that lease out pressure vessels? According to our internal mech engineer, pressure vessels are fabricated fit-for-purpose and I won't find any companies leasing them out.Advice and help appreciated.
RE: Pressure vessel for hire/lease as fixed-bed reactor
Please do not double post as you will better response if the information is given in one Forum.
If you want to post in different Forum, do so and Red Flag the unwanted post.
What's the minimum acceptable volume needed?
Good luck,
Latexman
After some thought and one phone call we did rent or lease/purchase some equipment, 3 glassed lined reactors.  We ended up sending 2 back and purchasing one.  If my recall is up to par I think we got them from someone like LCEC,
Not in your area but there should be able to find a a used equipment dealer in your specified area.
http://www.lcec.com/commerce/index.jsp
What is the required material of construction?
What type of access require?
What L/D is required?
