0-3" Thick Grout Needed
Contractor poured an exterior slab too low resulting in the exterior metal stairs hanging about 3" above t/slab. I need to provide a 'ramp' up to the bottom of the stairs for accessibility and anchorage. The material needs to go from feathered edge to approximately 3" over an area around 12 SF. Anybody know of a worthy product?
RE: 0-3" Thick Grout Needed
Make sure the landing is level when you finish...code requirement.
