Routing Cable issue
Routing Cable issue
When editing a route in Routing. The cable wil not follow the path. If I turn on view sketches the sketch path is where I moved it, but the resulting outside cable will not move (see attached jpg senario 1) or dissappears all together, never to return (senario 2). All done with routing tools, not 3d sketches & extrusions.
RE: Routing Cable issue
Dan
www.eltronresearch.com
Dan's Blog
-Joe
SolidWorks 2009 x64 SP 5.1 on Windows XP x64
8 GB RAM - Nvidia Quadro FX1700
Each route is its own sub-assembly, so I assume that cable_1 etc.. are the sub-assemblies (individual routes)
-Joe
