Heirarchy Numbers in Assembly
Heirarchy numbers?  I have generated multiple sub assemblies that can be configured using the equation editor portion of the program.  I would like to combine those assemblies to make a larger assembly that can make all of the sub assemblies adjust using the equation editor in the main level.  I found that the equations generated in the sub assemblies do not follow them into the larger assembly.  I also found that the Hi#'s change on the individual components.  Is their a identifier that does not change when loading a sub assembly into a larger assembly?  Or is their an option or setting that will maintain the Hi# between assemblies.  I can copy the equations from the sub assy's and paste them in the overall assy without much trouble.  If I change the prescript on the governing dimensions to match the new assembly prefix it will adjust the dimensions of the sub assembly without much difficulty.  However all of the suppress/unsuppress commands do not work because they have the wrong Hi#'s.  Ideas??
