1006 STEEL WHAT TYPE OF FASTENERS TO USE
Ok, big block of 1006 type carbon steel machined with various tapped holes.
There are other components being fastened to it with a mix of material types of fasteners. Some stainless and some Gr5.
I thought with cs you could not use a ss fastener? Did not see any notes on any of the drawings about using never-seize.
Am I missing something?
What would be the type of fastener to use with 1006?
RE: 1006 STEEL WHAT TYPE OF FASTENERS TO USE
Could you post a little more details?
What size fasteners?
What is the loading?
Corrosion resistance needed?
Just mounting a 9'long 1x1 thin wall tube on the top surface. The components will be inside and no one has ever mentioned an issue with corrosion resistance.
