wall mounted disc flushing valve for pig launcher washdown sump
I am looking for wall mounted disc flushing valve for pig launcher washdown sump. if you have information could you pls send vendor hyperlink and info. Thanks....
RE: wall mounted disc flushing valve for pig launcher washdown sump
???? Pressure class, size and fluid please!
Note: some 8" gatevalves have PN16 borings, and housing certified for PN16 with open gate, but are only certified for lower working pressure than PN16.
As long as you describe the valve specification correct with your necessary working pressure, there is no problem getting a correct valve quoted for your purpose, with a full PN16 certified knifegate, but it will narrow the number of possible suppliers/producers. Solutions in all SS or SS/normal steel housing or nodular cast iron housing, or for that case in exotic materials exists.
If knifegate one size above 8" could be considered, as some gatevalves have guidings limiting the sidewise full opening in a small degree. Check in case if this is a problem regarding fitting or wear on plug and valve.
I can give you some suggestions if you state your country and necessary working differential pressure (across closed gate). Do this pressure also need to be PN16, or can you use PN10 or even 6? Is your flanges PN16 or other standard?
The reason for the details is that some suppliers will have limitations, others not, if you require the 'full package'.
