Varying Line Thickness on Part Drawing Question
I'm fairly new to Solidworks (Have about 1 month of usage) and I was wondering if there was a way to change the line thickness of a feature in a part drawing. I know you can change the line thickness of parts in an assembly drawing by using the Component Line Font command but I am not too sure if you can do the same for a part drawing without causing the entire model to change to that line style.
So is there a way to make the line outline of some features different in a part drawing?
MMix13
MMix13
RE: Varying Line Thickness on Part Drawing Question
-Dustin
Professional Engineer
Pretty good with SolidWorks
