Actual orifice area vs effective area?
Why is a valve's actual (certified) area less than the effective area, which is used in flow formulas to determine the capacity of a relief valve?
For example, for an API "L" orifice (effective area = 2.853 sq in) the certified orifice areas (ref National Board NB 18) for Crosby and Farris are:
Crosby: 2.025 sq in
Farris: 2.009 sq in
I would have thought that the "effective area" used for flow capacity calcs would have been less than the "actual" to provide a bit of unpublished flow capacity.
This came up as I was performing a Caesar relief valve dynamic analysis that required the "minimum diameter of the relief valve throat". At first I used the "API" orifice diameter and the calculated capacity was almost twice the published capacity for the valve. Once I used the "actual - certified" value for the particular valve, the calculated capacity was pretty close to the published value for an "L" orifice.
Anybody have any thoughts?
Crosby: 2.025 sq in
Farris: 2.009 sq in
RE: Actual orifice area vs effective area?
My mistake.
Thanks, you made me look closer at the two values.
I was comparing API effective area to actual Orifice Diameter. I hate it when that happens.
Bill
