zinc/aluminum flake dip-spin applied coatings
Does anyone know where (or if) I can find salt spray test data that compares,side-by-side in the same test, the corrosion resistance of zinc/aluminum flake coating systems from the various manufacturers like Doerken Delta MKS, Magni, Geomet,Sermagard, Whitford, Zintek, Empigard, etc?
RE: zinc/aluminum flake dip-spin applied coatings
The salt spray test was developed with the idea in mind to just compare the results and not have to run side by side tests.
Based on my experience with these coatings the surface preparation is key to a functional coating.
