Pump/Motor Alignment Literature
Hi guys,
Can anyone of you recommend some elementry online literature on pump/motor alignmnet techniques.
RE: Pump/Motor Alignment Literature
Try this on Google books:
Millwright's Guide
Good on ya,
Goober Dave
The link function doesn't work quite right above when you click it, so instead you'll have to highlight the entire address above and cut/paste it into your browser address bar.
(2B)+(2B)'  ?
Can you explain what you mean vpl?
What is step 3?... is there a better way to post a long link?  (other than maybe tinyurl)
(2B)+(2B)'  ?
Pete
When you post a reply there is information in red on the left hand side.
It starts off with Before you start.  Then it says Step 1 Message with the big white box where you type your message right below it.
Next, it says Step 2 Options with four check blocks (E-mail Notification, Emoticons/Smileys, Process TGML and Signature).
The next one says Step 3 Attachment and there is a box with a paperclip next to it.  If you enter the http address in that box then it will appear in your post as a box with a paperclip below your signature.  For example, look at the bottom of this post where I captured your entire link.
Finally there is Step 4 Submit Post with the Preview and Submit buttons.
I hope this is of help to anyone posting links.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Aha, that step 3.
Thanks, that'll be useful.
(2B)+(2B)'  ?
