create cross section with element beam188
How to create cross section diferent ,add to sectiom in file world.
I am using Beam188.
I am using Beam188.
RE: create cross section with element beam188
Add a file of the new section
You have the option to input user defined cross sections. However, in this case, you need the input the inertia and area yourself. ANSYS will not calculate it for you. In Common Section - subtype, you will find a smily face. Just enter your beam's properties that you will get what you need.
Hope it helps.
Cheers.
