Composite Layup on a cylindrical shaped body
I am trying to do a composite layup on a cylindrical object but I am not sure how to go about it. The user manuals are not that clear on how to go object it when you need composite layers in the radial direction. One thing I need to make sure is that the object is rigid so no displacement due to temperature changes. I just need to see how heat flows from the center to the outside with heat generation at the center of the cylinder.
Any help would be appreciated
Thank you
Thank you
