Keyboard shortcuts for principal views
The following thread explains how to set up keyboard shortcuts:
http://www .eng-tips. com/viewth read.cfm?q id=220591& amp;page=5
The original poster wanted to set up Ctrl+1 through Ctrl+7 to toggle between model views, like in SolidWorks. Coming from SolidWorks, I wanted to do the same, but there was no easy way to discover the corresponding commands that the keystrokes should be matched to.
I discovered the ideasCommand.xml file in the IDEAS program directory and - after some trial and error - found that adding the following entries to ideas.ini:
Accel101=CONTROL-F1;icon;GUI_z_view
Accel102=CONTROL-F2;icon;GUI_AXSYM_VIEW_MAN
Accel103=CONTROL-F3;icon;GUI_nx_view
Accel104=CONTROL-F4;icon;GUI_x_view
Accel105=CONTROL-F5;icon;GUI_y_view
Accel106=CONTROL-F6;icon;GUI_AXSYM_VIEW
would map Ctrl+F1 through Ctrl+F6 to Front, Back, Left, Right, Top, Bottom, in that order (I-DEAS doesn't allow you to map to CTRL+1, etc.). The labels (Accel101, etc.) don't need to be the same in your ini file. I believe they just need to be unique.
Rob
http://www
Rob
Rob Campbell, PE
RE: Keyboard shortcuts for principal views
Using this method, the keyboard shortcuts become:
Accel101=CONTROL-F1;command;/v v pe of; e 0 0 1 0; okay;
Accel102=CONTROL-F2;command;/v v pe of; e 0 0 -1 0; okay;
Accel103=CONTROL-F3;command;/v v pe of; e -1 0 0 0; okay;
Accel104=CONTROL-F4;command;/v v pe of; e 1 0 0 0; okay;
Accel105=CONTROL-F5;command;/v v pe of; e 0 1 0 0; okay;
Accel106=CONTROL-F6;command;/v v pe of; e 0 -1 0 0; okay;
Accel110=CONTROL-F7;command;$ /v v pe of; e 3 4 5 0; okay;
Using the ideasCommand.xml method, I was never able to map the left or isometric views correctly, so this is much better.
Rob
Rob Campbell, PE
