How do I assign a terminal in Cedrat Flux 10.2?
I "inherited" Flux 10.2 due to an untimely death in the company.
I have the complete solenoid design but can not solve because I don't know how to add the terminals. The orient wires to coil conductor regions has options for external or internal terminals.
The external terminal option wants a face and when I enter a face, I get "No output group of face of the conductor can be find for this region. Please, modify the geometry of volume of this region or modify the input group faces of the conductor."
The internal terminal option gives me "The select region has no internal faces. Change the terminal type in external."
If I chose "electric terminal" and then edit, I get "Edit: No existing entity can be applied for this command."
I have terminals on the circuit in Cirflu but that does not allow me to specify them either.
Thank you for your help, as I am at a loss here.
