How can I apply a triangular load over an elastic body?
Hi
I want to apply a triangular load at the top of a square phantom for an input file in abaqus.
 Should I use two kind of load one hydrostatic and one unifome load at the same time using DLOAD?
how should I do that?
Thanks in advance for your kind help.
 Shadi
RE: How can I apply a triangular load over an elastic body?
Sounds a reasonable approach.
What is a square phantom? Is it a ghost that likes orchestral music? Just a thought.
Tara
Can't you use a hydrostatic load only? With hydrostatic load you can model any kind of triangular load...
matias
as far as I know with hydrostatic load I can apply load from 0 (at beginning of the surface)to a ( at the end), but I want to apply loading from a (at the beginning  of the surface) to b(at the end of the surface)
and the question is how can I apply to kind of loading one uniform and one hydrostatic that it can be a representative of the kind of loading I want using superposition principle?
p.s: phantom is something mimicking the tissue part in my model.
 Thanks .
Shadi
and the question is how can I apply two kind of loading one uniform and the other, hydrostatic that it can be a representative of the kind of loading I want using superposition principle?
 Thanks .
Shadi
I believe that loads are additive, but as friedmind suggested, you could apply a hydrostatic loading and adjust the parameters so that you got the triangular loading you required. The point at which the hydrostatic loading is zero wouldn't be on the model of course but some point in space.
Tara
