Axis Constraint - Mechanica
Working in Pro-Engineer Mechanica.
Trying to constrain movement of a surface in a negative axial direction and allow freedom of movement in the positive direction.  Any comments on how this is controlled?
I don't think this is the purpose of the "Prescribed Displacement" control in the Constraint Dialog.  If it can be achieved with this by using a range, I can't figure out the syntax for allowing a positive range of movement.
Thank you.
RE: Axis Constraint - Mechanica
Try to figure out how to write a function for that constraint, in the same window you are talking about near the "Prescribed Displacement" you will find a choice of adding a function. For me I couldn't do it when I tried recently.
Contact regions.
Good luck,
Steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
www.seymourecg.com
