inertia properties
inertia properties
inertia properties
Hello all,
I'm building a dynamical model of an exoskeleton. To determine the inertial properties Solid Works is used (version 2010).
If I look at the output in the mass properties section, something strange happens to my opinion.
If the rotation matrix is pre- and postmultiplied with the diagonal inertia matrix(Equation used: Iout = inv(R)*Iinert*R
), the solution does not correspond with the other output (numbers are correct but minus signs are wrong). An example is included below.
Can somebody help me?
Mass properties of selected components
Output  coordinate System: Coordinate System4
The center of mass and the moments of inertia are output in the coordinate system of 100_Exoskeleton-without motors-update_20sim_07022011
Mass = 146.3293 grams
Volume = 50645.2787 cubic millimeters
Surface area = 23236.8002 millimeters^2
Center of mass: ( millimeters )
    X = -48.3769
    Y = -0.8218
    Z = 82.9338
Principal axes of inertia and principal moments of inertia: ( grams * square millimeters )
Taken at the center of mass:
R: Ix = (-0.6466, 0.0162, 0.7627)       Iinert(diagonal matrix    with Px,Py and Pz on diagonal) :Px = 53372.2917
         Iy = (0.7625, 0.0442, 0.6455)                                     Py = 546886.0625
         Iz = (-0.0233, 0.9989, -0.0409)                       Pz = 560232.1085
Moments of inertia: ( grams * square millimeters )
Taken at the center of mass and aligned with the output coordinate system. Iout
    Lxx = 340561.7431    Lxy = -4846.6654    Lxz = -243381.0661
    Lyx = -4846.6654    Lyy = 560073.6574    Lyz = 6627.9462
    Lzx = -243381.0661    Lzy = 6627.9462        Lzz = 259855.0621
RE: inertia properties
I believe that is because your center of mass is located in two negative axis and one positive axis.
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
