Strange section view behavior
one of our users has a flat pattern on a drawing sheet which is dimensioned. He has then added a second view to the sheet which he wants to section, however as you can see by clicking the link, when he attempts to create the section view, it screws up the flat pattern in the other view. Why does it do this, and how can I stop it from happening?
http://screencast.com/t/LCZcLmZDcw3
Many thanks.
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX7.5 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
RE: Strange section view behavior
Wow, I never seen anything like that.
I can only suggest something.
Move the flat pattern to another sheet, then add the section view, and after that move the flat pattern back to that sheet after the section view is placed.
Was this done in NX 4.0 or NX 7.5?  I tried this in NX 7.5 and it worked fine.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John
It was done on our live system using NX4. I have seen it once or twice before a long time ago. Very strange :-|
Best regards
www.jcb.com
If you used NX 4.0, that was before we even had a Flat-Pattern option in NX Sheet Metal.  What you described was for all intents and purposes, not supported.  If this only happens occasionally, I'm not sure that if there's anything we can do for you even if we were able to reproduce it on demand since NX 4.0 is no longer fully supported (with big fixes).  I would recommend that you move as ASAP to a more modern release, preferably NX 7.5.
John R. Baker, P.E.
Industry Sector
Cypress, CA
