Producing Propylene by Dehydrogenation: explanation of the process
I recently visisted a refinery to comission our S.G. / M.W. meter. I wanted to get a better undestanding of the process, but due to time limitations and language barrier I could only learn a little. The refinery (can I say the company name on this forum?) made propylene from propane using dehydrogenation. I was told that the M.W. measurement was particularly important for the three compressors.
Could somebody please explain the dehydrogenation process, what part the compressors play, and why the measurement is needed? Could the process run without this measurement?
I really appreciate any help you can give.
Robin
Robin
RE: Producing Propylene by Dehydrogenation: explanation of the process
For a chemical process, the mass of the feed stocks need to be in correct proportion. S.G /M.W are used for mass flow rate calculation in flow metering. Mass is constant irrespective of temperature and pressure.
M.W are used for gas flow measurement/control and surge control in centrifugal compressors.
