Diameter dimension
Diameter dimension
Hello to all.
How can put a diameter dimension like the image, the arrow on one side only?
Thanks to all.
Best regards.
Thanks to all.
Best regards.
RE: Diameter dimension
In answer to your direct question I do not know how to make the dimension display as you want. However, you might try just using a note.
ArtL, you are correct that if you can't measure it you shouldn't dimension to it. However, I'll bet that this feature is only incomplete in this section and that its diameter is complete in a perpendicular view. AER73, you might consider showing the perpendicular view so the dimension would show without confusion.
- - -Updraft
2. Activate the dimension tool and pick on the spot where you want the dimension attached.
3. Click on the centerline you created.
4. Pull the dimension off to the left of the centerline before placing it. It will turn into a diameter dimension. Place the dimension.
5. RMB on the witness line you don't want to show and click "hide witness line". RMB on the dimension line near the arrow you don't want to show and click "hide dimension line.
-handleman, CSWP (The new, easy test)
Thanks to all.
Best regards.
