Help with converting measurements and dimensions
Hey, just a quick question. I have drawn up plans for a design, however, i have drawn in mm, as i work in metric. The tools however are in Imperial. That is inches.
Is there a way to convert the dimensions so that it measures in inches, but without redrawing/ scaling my work.
Thanks, Ghillie
Thanks, Ghillie
RE: Help with converting measurements and dimensions
Try going to Format/Dimension Styles and changing the text properties to a smaller size font. You should also be able to edit the arrows and extension lines to suit your needs.
Bill
