what is the HVAC filter material?
Hello Everyone,
To avoid dust goes into a electrical panel, a unknown filter material is installed on this panel. As time goes, the filter has to be purchased and replaced it. However I don't know what is that material. The filter pictures are as enclosed. Would any one can identify it? Thank you.
http://files.engineering.com/getfile.aspx?folder=3eace20d-1b73-49c3-823d-3fe3ca749933&file=IMG_5506.JPG
http://files.engineering.com/getfile.aspx?folder=d0df9fb3-a78c-4d12-b07e-1f27ef5124d5&file=IMG_5508.JPG
RE: what is the HVAC filter material?
That is a so called "spun filter media" It should be readily available at most heating and ventilating supply shops.
  It is available in different mesh sizes and thicknesses.
Take a filter with you to match it up.
B.E.
I think it's camel pubic hair.
If a 30% pleat doesn't dampen your draw through too much, you might want to go with that.
