Etabs beams
Etabs beams
Dear all,
in Etabs, is it better to keep a beam as 1 line between 2 columns or is it better to divide the beam line on nodes intersecting with the beam.
Is there any difference between both cases and what about if there is a line load on beams?
i appreciate ur help
RE: Etabs beams
If you break it up, you will get results for each segment only.
Internally, ETABS creates a node every time a beam frames into another beam.
