A discussion which might related to recent roof collapse
I have recently done some research and analysis on metal building rigid frame under snow load. I found there are 2 issues which I would like to bring here to discuss with you guys:
1. I understand that AISC-13th does not explicitely require to check the I-Beam web buckling or crippling strength under compression at suspended beam portion. It only request to check web buckling or crippling strength under compression at bearing location. However, to me, I think it is an item which needs to be checked, because to guarantee the flexural strength of the whole beam under applied load, the web of the I-Beam at every cross section has to be able to resist applied local vertical load without local buckling or crippling.
2. I understand that it is a common practice (at least in U.S.) that for most built-up I-Beam, only single sided weld is requested as is shown in Figure 1.a. in attached document. To me, with single sided weld, the web can only considered as pinned at both ends when checking its compression buckling capacity, only when double sided weld, then the web can be considered as fixed at both ends when checking its compression buckling capacity under local vertical load (Figure 1.b.).
If above 2 issues are true, then I'll bet that there are many metal buildings which can not pass that local I-Beam web buckling check.
I am not sure how much it related to the the recent roof collaps case, that is why I would like to bring this topic here to discuss.
Thanks.
Thanks.
RE: A discussion which might related to recent roof collapse
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
