Code Requirement for Control Ground
I have an installation where shielded 18/2 cable was used to deliver 24V power to a control actuator. The installer used the shield as the ground.
Is this code compliant?
If so, is it otherwise acceptable?
Thank you
Thank you
RE: Code Requirement for Control Ground
If you describe your circuit in much greater detail, you might get a more thorough answer...
Good on ya,
Goober Dave
thread248-279001: Safety grounds - several questions
