Concrete Sprinkler Tanks
Hi Guys
I am a UK sprinkler designer and have been tasked with the joys of a designing a concrete sprinkler tank to nfpa 22. The System is designed to nfpa 13 (500USG @ 140) reduced capacity tank of 84m3.
I have been given a space in basement 6 to construct a concrete tank which has no high level access from the side or topside of tank to get inside and maintain the ancillary equipment. Have any of you designed a low level access plate? Are there minimum dimensions I should stipulate to the builder?
I also need to look at a proper water tight seal as the need for the butyl liner is no longer an option.
Your advice is much appreciated and any dwgs.
Signed A disgruntled Sprinkler Designer with limited NFPA experience! haha
RE: Concrete Sprinkler Tanks
